Skip to main content
This version of GitHub Enterprise Server will be discontinued on 2025-06-04. No patch releases will be made, even for critical security issues. For better performance, improved security, and new features, upgrade to the latest version of GitHub Enterprise Server. For help with the upgrade, contact GitHub Enterprise support.
Configuring the IP address using the virtual machine console
By default, GitHub Enterprise Server retrieves network settings via the dynamic host configuration protocol (DHCP). If your platform supports it, or if DHCP is unavailable, you can also configure the network settings using the virtual machine console.
Note
We do not support adding additional network adapters to GitHub Enterprise Server.
  1. Using your virtualization platform tools, open the virtual machine console.
  2. To start your network setup, press S.
  3. Choose to configure the IPv4 or IPv6 protocol.
  4. Configure options for the protocol you chose.
  5. To finish configuring your settings, press D.
